System freezing up, mouse and keyboard active, help please
I have a 2009 iMac that I replaced the hard drive and upgraded the memory, now the system is freezing up.
Here are the spec on the system and hard drive I put in:
2 TB Toshiba DT01ACA Series 3.5-inch SATA 6.0Gb/s (3.0Gb/s and 1.5Gb/s backwards compatible) 7200RPM Hard Drive with 64MB Cache; Toshiba
My iMac's specs:
Introduction Date: March 3, 2009 Discontinued Date: October 20, 2009
- Processors: 1 (2 Cores) Architecture: 64-Bit
- Processor Speed: 2.66 GHz Processor Type: Core 2 Duo (E8135)
- Turbo Boost: N/A Custom Speeds: N/A
- Processor Upgrade: ZIF Socket FPU: Integrated
- System Bus Speed: 1066 MHz Cache Bus Speed: 2.66 GHz (Built-in)
- ROM/Firmware Type: EFI EFI Architecture: 64-Bit
- L1 Cache: 32k/32k L2/L3 Cache: 6 MB (on chip)
- RAM Type: PC3-8500 DDR3 Min. RAM Speed: 1066 MHz
- Standard RAM: 4 GB Maximum RAM: 8 GB
- Motherboard RAM: None RAM Slots: 2
- Video Card: GeForce 9400M VRAM Type: Integrated
- Standard VRAM: 256 MB Maximum VRAM: 256 MB
- Built-in Display: 24.0" Widescreen Native Resolution: 1920x1200
- 2nd Display Support: Dual/Mirroring 2nd Max. Resolution: 2560x1600
- Standard Storage: 640 GB HDD Std. Storage Speed: 7200 RPM
- Storage Dimensions: 3.5" (26.10 mm)
- Geekbench 2 (32): 3680 Geekbench 2 (64): 4064
- Geekbench 3 (32): 1473 Geekbench 3 (32): 2589
- Geekbench 3 (64): 1595 Geekbench 3 (64): 2840
좋은 질문 입니까?
댓글 2개
Your systems specs: iMac 24" 2.66 GHz Core 2 Duo (Early 2009)
Your HD's specs: Toshiba DT01ACA300 (3 TB), DT01ACA200 (2 TB), DT01ACA100 (1 TB) & DT01ACA050 (500 GB) drives
Dan 의
What speed of ram do u have in there?
Lord Vader's Finest Rocketeers 의
