주요 콘텐츠로 건너뛰기
LG 대형 스마트폰, 2014년 가을 출시. LG는 Quad HD IPS 스크린과 13-megapixel 카메라를 자랑합니다.
180 질문 전체 보기
LG G3 Signal on and off every few seconds after screen replacement
Hi!
I fixed my phone yesterday, replaced the LCD and digitizer with all its frame.
I took everything out from the previous case and moved them to their new home.
Since then, my signal goes off and on every 10 seconds or even less.
I can call, use data and everything, but the signal turns off completely for a few seconds and than comes back and again...
Any solution? What components should I check for problems?
Thank you!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
It's probably the little daughter board at the bottom which is apparently the antenna.
Iv'e purchased one from ebay for about 13$ and will see if it will solve the problem.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
Noam Cohen , If phone was working with the old display perhaps try reinstalling it to see if you purchased a faulty display. If not take the phone back apart but this time clean all the connections(Qtip dampened with 90% or better Isopropyl Alcohol) check all pins for damage and straighten very carefully with tooth pick and reseat connections securely. Check the board for loose/damaged/burnt components and repair as required.
Check the battery with DVOM to see if it is taking charge, reassemble the phone and try. Good luck.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Noam Cohen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 304
