주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
How to fix the Fan header
I was disassembling my ps4 and got down to the fan header. I thought that you had to pull the cord horizontally and did that without knowing that I had to do it vertically. So then I accidentally broke the fan header but was able to repair it, temporarily, with the ps4 shutting down most of the time due to overheating. I want to know if there is a permanent solution to fix the fan header, so then I don't have to play with it all the time to keep the fan running.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
Can you post pics
this will help with posting a picture
기존 질문에 이미지 추가하기
댓글 달기
답변 3개
선택된 해법
It sounds like you must be talking about the fan connector on the motherboard. If that's the case then you have several options:
1) Solder the fan wires directly to the correct pins on the motherboard
2) Replace the connector...if the connector on the motherboard itself is broken then you would have to probably get a connector from a junk motherboard. If it's the connector on the fan side you could just replace the fan.
3) You could purchase a new motherboard...this option is obviously not the best since it's so expensive but it is an option.
I hope this helps. Good luck!
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Hey Steve, I have been trying to buy a new set of fan headers (10 pieces) from Ali Express but they sent the plugs from the fan side NOT the sockets I thought I ordered, now they have blacklisted me from buying anything because I returned the wrong items! Where do you suggest I can source the correct item(s) as I am in Australia and it is hard to get parts for consoles? Looking forward to help.
댓글 달기
This happened to me but it was on the fan side. I just discarded the plastic and connected the cables directly to the mother board without having to solder. PS4 1100 series
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
How did you manage to do this?
댓글 달기
I did it with a needle it lifted it and slides out after
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Astrowings230 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 41
전체 시간: 6,159
