What's the use of the foam / cushion / sticky pads on flex cables?
I keep damaging the foams you find on flex cables. I was wondering what their use is. Simple question but it's a question that keeps coming up in my head hehe :)
좋은 질문 입니까?
좋은 질문 입니까?
I agree with Ben's comment. I also believe they help keep the connectors tightly in place when the metal shield for the display is screwed back in place. This could help the connectors from loosening if dropped and so on.
If you are trying to reuse them but can't seem to remove them you can also buy them in bulk. That may be a good option if you do a lot of iPhone screen replacements. I use a razor and slowly loosen one end. I try to find a corner that has a bit of metal exposed and push the razor under the pad and slowly loosen the adhesive then you can slowly pull it off and reuse it. I have seen them for sale on sites like eBay if you prefer to buy them. Here is a link to some on eBay: http://m.ebay.com/sch/i.html?_nkw=iPhone...
해당 답변은 도움이 되었습니까?
To maintain positive pressure on the connectors so they don't pop off.
Some phones even came with some cushions missing and they work fine.
해당 답변은 도움이 되었습니까?
To avoid people cutting themselves with the metal part of the flex cables or allows them to be evenly pushed down when a metal plate cover is on top.
해당 답변은 도움이 되었습니까?
The foam on the connectors holds the connector in place once the phone is reassembled. The foam on the flex cable itself is normally a conductive pad that connects to the part that compresses it when reassembled.
Sorry Ben, I have repaired computers, phones and tablets professionally, and have not heard of anyone cutting themselves on flex cables or flex cable connectors, with or without foam on them. You are more likely to be cut by paper than a flex cable.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 875
댓글 1개
Thanks all !
I also asked a seller on eBay, and he basically says the same as you guys.
Again.. Huge thanks :)
Didier Daniel 의
