주요 콘텐츠로 건너뛰기
Club Car Golf Cart/클럽카 골프카트 브랜드의 이름을 따서 골프카 또는 클럽카라고 불리는 가스-구동 및 전기 골프 카트 지원.
494 질문 전체 보기
Golf car runs when cold after warming up quits moving forward or rever
My ez go gas golf cart runs fine when cold after it warms up its like the trans went out wont go in forward or reverse at first it would still run in reverse for awhile about 5 more mins and then nothing in either direction .After cooling down overnight then it would run fine for about 20-30 mins and then quit going again .
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
I have the same problem and I have replaced the belt and clutches and the problem is still there.I even changed cdi box new rear end carb and accelerator cable new coil..Nobody can figure this out..ive spent over 1100.00 trying to solve issue.
댓글 달기
답변 1개
선택된 답변
@musicman4577 , billy, Sounds like a drive belt or clutch issue, check the belt for being worn, when a belt gets to a certain thickness(worn) it will cease to work when warm or may not work at all, replace the belt or if adjustable, adjust. Check your clutch for proper function and wear. Check the links below to help trouble shoot your cart 2nd link is the service manual for gas powered carts. Good luck.
http://www.golfcarcatalog.com/golf-cart-...
http://www.specialtycartz.com/pdf/ezgo_g...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
billy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 21
전체 시간: 2,091
