주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
iPhone 6s touch screen unresponsive on left side
I have a iPhone 6s whose touchscreen sometimes becomes unresponsive on random. When it becomes unresponsive half of the screen doesn't respond to touch and sometimes the entire screen for about 10 seconds then it work or if not wen I lock and open the device what could the problem be cause there are times it works perfectly then sometimes it doesn't need help.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 2개
선택된 답변
It's either a bad replacement screen or liquid damage on the logic board.
해당 답변은 도움이 되었습니까?
점수 5
댓글 3개:
How are can u test for liquid damage?
I found out that the screen becomes unresponsive when the brightness increases, in the day when the phone Is out in the sun it becomes unresponsive when I'm indoors it works somewhat okay I turned on the LED flash of my other phone and beamed it into the ambient light sensor the screen got bright and the touch unresponsive this looks like a logic board problem don't you agree?
Was the screen replaced? If yes then replace front camera flex.
댓글 달기
I also have the same issue.. my screen is not replaced ..the phone is still on company seal.. they why it shows like this??
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Beris Smith 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 12
전체 시간: 13,670
