Weak blue spark but will not fire
My cart turns over well but does not fire I have changed the coil, fuel pump, fuel filter,cleaned contact wires.
좋은 질문 입니까?
좋은 질문 입니까?
@ligordo ,Larry, Spark plugs producing weak/no spark. Spark plug gap wrong, reset gap to recommended setting, faulty spark plugs, faulty coil wires, Ignitor faulty replace, Check first all wires plugs, grounds for loose/corrosion/damage, Pulse unit faulty replace, Check first all wires plugs, grounds for loose/corrosion/damage. See link below, service repair manual with more trouble shooting and testing info.. Good luck.
해당 답변은 도움이 되었습니까?
white or blue spark is good! orange or yellow is weak. sounds like you have good spark. pull your fuel pump off the crankcase and get yourself a good pressure/vacuum gauge to check your crankcase pressure. it should be 1-1-1/2 pounds. if the needle doesn't move, you may have a bad rear crankshaft seal. if pressure reads good, check to make sure the gasket and o-ring under your fuel pump are in good shape. check fuel pressure at carburetor. if you have good fuel pressure at carb, you may need to clean the carb.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 4
30일 전: 27
전체 시간: 3,897
