주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
6s plus losing Touch ID after screen replacement.
I've replaced many iPhone screens, transferring the button to preserve the Touch ID, but this is the third 6s+ that I've replaced and all three have failing Touch ID, even with the original button. Is there something unique about the 6s+?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Did you checked the ribbon that goes from button to the logic board?
댓글 달기
답변 1개
I have done quite a few 6s Plus's and have never had an issue with Touch ID so as far as I know there are no unique quirks to them when it comes to the home button other than the usual (don't damage the ribbon cable, remove battery and drain power before removing connector ect.)
Are you using OEM or aftermarket screen? The home button cable is built in to the screen assembly on the iPhone 6s Series and the aftermarket screens frequently have issues so if your using aftermarket screens you may need to switch to OEM to avoid this issue.
Also make sure the cable is not damaged and is seated correctly into the board connector, if the connector is not quite fully connected then you will get the click function but not the Touch ID.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Garrison Babbitt 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 157
