주요 콘텐츠로 건너뛰기
Ford Motor Company/포드 자동차 승용차 및 트럭 수리 안내서 및 지원.
1396 질문 전체 보기
Water in fuel was accidentally poured in
Tried to start before aware water was poured in will not start at all what do I need to do
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@steelbear63, Daniel Halbert, You did not state your year, model, engine, etc.. Best to have the entire fuel system drained. Fuel very flammable be careful. The safest way to drain the tank is to use a siphon pump as shown in links below. 1st link below show how to remove fuel rail schrader valve to drain tank lines of of water contaminated fuel. You could also have towed into a good local shop and have a tech do it. Good luck.
https://www.youtube.com/watch?v=zF6XZMDM...
https://www.thoughtco.com/vintage-cars-a...
https://www.yourmechanic.com/article/how...
http://preparednessadvice.com/bugging-ou...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Daniel Halbert 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 36
