주요 콘텐츠로 건너뛰기
2011년 하반기 모델, A1278 / 2.4 GHz i5 또는 2.8GHz i7 프로세서.
591 질문 전체 보기
How can I fix video recall
Hi,
My macbook pro 2011 was recalled last year 2016 for video card repair
1 year and 1 month later- feb 2017 it broken again , this time not under warranty .
So apple told me told me my mac was a write off because they dont make that part anymore ; it cant replaced.
I have an older model that still works fine... I found it a bit dodgy ...
any ideas , solutions what should i do .
Thank you
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Well, I do have some good news! Most likely you don't need a new logic board. as it turns out there are a few tantalum capacitors which wear-out from high heat as they are near the GPU logic which can get quite hot.
You'll need to send your logic board out to someone who knows about the issue and have them replaced with a better capacitor. Otherwise you can still find the logic boards on the open market.
As to the reason the caps went you maybe pushing your system a bit hard. Laptops are not desktops and are not designed to run heavy graphical gaming which is often the reason why they fail. The age of the technology the system was designed with also plays a role here newer systems can handle more.
I would recommend running a good thermal monitoring app like: TG Pro as it can help monitor your system so you know when you're pushing it a bit too hard.
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
@danj can you be more specific on those caps as I'm going to run into this and need to know how to fix.
Did you see this? Problem with NVIDIA GeForce GT 330M 256 MB?
My logic board repair guy tells me many of the GPU issues are related to poor component choices and location.
Give gfxCardStatus 2.4.3 app a try. It allows you to force the OS to use the intergraded GPU within the Haswell chip.
Here's a bit more on its use: gfxCardStatus for Mac If you can run the system off of the intergraded GPU without any problems you've isolated it down to the external GPU logic.
Thank you Dan
댓글 달기
귀하의 답변을 추가하세요
July moroe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 129
