주요 콘텐츠로 건너뛰기
eMac은 교육 시장용으로 설계된 올인원 G4-기반 Mac입니다. CRT 화면을 사용하는 마지막 Mac이었으며 학교 및 기타 기관에 저렴한 가격으로 판매되었습니다.
47 질문 전체 보기
Airport Extreme Card not detected
I have a 800Mhz, 512MB, Mac OS 10.4.11 eMac.
It did not ship with an Airport Extreme card so I have sourced one and attempted to fit it. I put in as normal (above disc drive) and booted the system but it has not been detected. I later tried an Apple Hardware Test and it didn't even find a Card to test.
I know this card works because I put it in my iBook G4 and it worked fine. I then took the card that was in the iBook G4 and tried it in the eMac. Exact same problem. What is wrong with my eMac?
I appreciate any response, thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 4개
선택된 답변
The reason you are having difficulty installing an Airport Extreme card in your eMac is because the 700/800MHz models use the older Airport card.
You can get one here on iFixit: [연계 제품이 누락 또는 비활성화 됨: IF143-010]
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
i must have skipped over that part.... you are correct.
댓글 달기
Hmmmm?! I have to disagree with the answers here. My reasoning is this:
I have 10 800 MHz eMacs. The standard Airport card WILL NOT fit in them; I just tried it. The slot provided for card installation is slimmer than the Airport Card, and slightly "stepped" on the sides (like an Extreme card).
As to why the card is not registering in your eMac:
Firmware issue
You should double check the devalias and see if the card is listed there. If it is...ouch! If it isn't:
Time to do the old nvram reset, and set defaults. Remember, computers need to be reminded what they are, and what they are supposed to do, once they have been upgraded. That eMac may not know it has the wireless card, because it was never shipped with one, or been intended to have one. The price of buying school surplus.... <sigh>
Give her a good old firmware "slap", and see what she does.
Update
Further proof of my response:
http://support.apple.com/kb/ht3024
eMac ATi and eMac (USb 2.0) both show Extreme supported NOT standard Airport.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
You need one of the regular PCMCIA AirPort Cards
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I voted this down as your answer is redundant. :(
댓글 달기
My emac does not recognize the airport extreme card I have installed. Help!
emac
PowerMac4, 4
PowerPC G4 (3.3)
1GHz
256 KB
512 MB
133 MHz
4.6.4f1
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
QEII Student IT 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 10
전체 시간: 6,755
