주요 콘텐츠로 건너뛰기
전문 작업을 위해 설계된 농기계 및 건설 차량을 포함하여 천천히 움직이며 큰 일을 처리하도록 설계된 기계의 수리 안내서.
Why is the tiller not spinning when the PTO shaft is?
It seams to be the part between the PTO shaft coming from the tractor and the gearbox on the tiller. From the looks of the diagram I found online it looks like the friction clutch assembly is just spinning freely around the shaft that goes into the gearbox on the tiller. Not sure what could be the problem or what part I may need to fix it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 4개
@rogershepherd post the diagram and a few images on what you are working on with your question. Use this guide 기존 질문에 이미지 추가하기 for that. we'll need to know what tractor and what tiller. Right now it sounds like the PTO out is okay, just nothing happening on the tiller end. Check for any shear pins and the drive.
Usually its just the sheer pin designed to take the torque of a sudden stop in the tiller (like hitting a large rock) and not breaking parts in the tractor or tiller by having the small sheer pin sheering in half...
Yes .,. This is what I’m thinking is going on with my county line ... thank you ...stay safe and well ... take care brother
댓글 달기
답변 3개
가장 유용한 답변
without seeing it in person or a good video, i sounds like the clutch is bad, there should be fiber plates in between ,they can wear if the pack is allowed to loosten. Sometimes you can tighten the bolts that go through the springs,(usually about 6 ) tighten each bolt an the same amount of turns to keep pressure even.
Another way you can check to be sure it is the clutch pack (because it could be the drive chain jumped off), raise and block up the tiller so it cannot fall, shut tractor completely off and remove key, engage pto with engine off, now reach under the tiller and rotate the blades, if the one side of clutch pack rotates but does not turn the shaft half, it is the clutch. BE CAREFULL! DONT PINCH OR CRUSH YOURSELF. BE SURE TRACTOR IS OFF. AND BE SURE IMPLIMENT CANNOT FALL ON YOU. NEVER WORK ON PTO EQUIPMENT WHILE RUNNING OR IF TRACTOR CAN ACCIDENTALLY START.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
look up slip clutch adjustments,
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Why is my roller not going down are spinning
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Roger Shepherd 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 31
전체 시간: 10,296
