주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Camera has horizontal lines through it.
I dropped my iPhone and the front and rear facing cameras were black. Thinking maybe the camera connecter cables have come undone I opened up the phone and connected the cables. After turning on the phone the camera worked, but then lines appeared in my pictures. If I gently tap the phone against my hand the lines disappear, Im not sure what is causing this. I have attempted to connect the camera connecter twice and Im still having this problem.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
My iPhone camera has been going black so I did a soft reset and I fixed it but these lines have came on the camera so if anyone has a solution please let me know at cgreene04@icloud.com
댓글 달기
답변 2개
선택된 답변
Due to the shock the camera may break, just order a new one and replace the old one
You can order it from IFIXIT or elsewhere
iPhone 6 Rear Camera 이미지
상품
$19.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Should I replace the front and rear facing camera hen sence I have had the issue with both cameras?
usually the front facing camera stops working when is a problem with the rear one. shocks usually affect the rear camera because they have moving parts inside
댓글 달기
replace both cameras and it will be perfect!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Cameron Skappel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 16
전체 시간: 5,844
