주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
iPhone 6 no display/backlight but powers on
i went to put on the screen on a iphone 6 it all worked then the wifi greyed went on so i changed the attenna then put it back in and it still didnt fix it so i then put the cover on and all screws in the same spot n screen was still on then i went to close the phone it then shut off no back light or display on i have already tried another screen that works and still nothing and the screws have not damaged the board
Update (03/22/2017)
here is a photo of the motherboard
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Sounds like the backlight ic is shot its repairable by a microsolder shop and runs about $170
Thing is all I did was went to close it and it shut off when I went to and I tried another working screen didn't help
댓글 달기
답변 1개
선택된 답변
Was battery unplugged at all prior to doing the repair or replugging of any cables?
Sounds like a backlight filter has blown.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
okay so i made sure the battery was not connected then i took off the screen and put it back on with all cables connected then i connected the battery and it turned on so i put all the screws in the right spot "still on" then i went to bring the phone down to close and it shut off no display so i tried a different screen off another working phone and still didnt display
댓글 달기
귀하의 답변을 추가하세요
Omg Backstabber 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 966
