주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
How important is the ambient light sensor filter?
Heeey everyone :)
After looking around the net I haven't found an answer to my question, so here goes..
How important is the ambient light sensor filter (white square filter) and what are its functions?
Some people told me it's a optical filter and not necessary, while someone else told me it's a light diffuser.
On white screens it's a dot instead of a square.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
The front camera flex should have a rubber gasket that sits on the pink ambient light sensor and has a small hole on it.
The sticker I think it's to make a good seal on the screen and the glass so that the sensor does not have like infrared or something bouncing somewhere else behind the screen.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
white screens should still be the same, its a white square on a white screen so im sure its just blending in, i dont see why it shouldn't and An ambient light sensor is a sensor that detects light to adjust the brightness of the screen. So not sure if its important, but you could remove it and see if it still works.
Hope this helps!
해당 답변은 도움이 되었습니까?
점수 2
댓글 6개:
What does that sticker do? What function does it have?
Yes I know that lol, but what does the sticker do?
The sensor itself is on the flex cable, together with the proximity sensor and front camera.
The sticker? I think its just used to protect the sensor from being damaged and possibly used to diffuse light. Those seem like the most logical reasons its there.
It’s not a sticker it’s a filter, and you need it for auto brightness to work.
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
Didier Daniel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 21
전체 시간: 6,134
