주요 콘텐츠로 건너뛰기
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 질문 전체 보기
Is it possible to put a 12MP Camera in the 12" iPad Pro?
I was wondering if you were able to open the iPad up and use the 12MP camera in the 12" iPad? I mean theres only a few differences between the 9" and the 12" iPad Pro's and the camera is a major one so I was wondering if I were to buy a 9" replacement 12MP camera and install it in the 12" iPad Pro, would it work? Could I then record 4K, etc?
Update (03/23/2017)
Thanks guys. I guess I'm stuck with the iPad Pro with a crappy camera. I mean I don't really take a lot of pics with the iPad anyhow. It's good enough to scan docs with. I just thought it would be cool.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
It probably isn't a good idea to swap hardware from device to device. The current draw/supply voltage may be different, or the iPad may not be able to understand the information that the camera encodes and sends over the PCB
댓글 달기
답변 2개
선택된 답변
I think its too risky to even try. Opening up the iPads is not easy! Besides, the rummer-mill is ripe with hints Apple will be dropping a refresh of the Pro series soon. I would hold off until then.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
가장 유용한 답변
Unfortunately, the connectors are different. Also, the iOS is specifically calibrated specifically included camera. If you were able to get a camera from a model to register, I don't think the camera would work properly.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Jeff Dodge 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 120
