주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
I replaced the charging port and it still won't charge
I replaced the charging port and it still wont charge. before the replacement I cleaned out the charging port with a q tip and a little isopropyl alcohol which made it so i could charge it only at a certin angle. any ideas?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
what percent is the isopropyl alcohol
you make it sound like the alcohol got past the port and got on to something else like an exposed wire
I replaced it with another charging port and still no luck
댓글 달기
답변 3개
선택된 답변
A phone that wont charge could be caused by multiple things:
  1. A defective battery. The iPhone 6S is well know to suffer from battery issues, perhaps your 6S Plus has a similar problem.
  2. A defective charge port. While you replaced it, these small parts are notorious for poor quality and you may have gotten a bad one.
  3. Debris or oil residues inside the port (you cleaned it with IPA already).
  4. Defective Lightning cables and charging bricks. Always use genuine Apple cables and bricks when troubleshooting problems.
  5. Finally, a defective charge circuit on the logic board. This could be caused by water damage, impacts, poor quality (i.e. the cheap stuff) Lightning cables and charging bricks, especially the "automotive" ones.
The first 4 you can troubleshoot yourself and the last one requires a micro-soldering repair (not DIY).
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Have you tried another cable/plug?
It is possible to have a faulty charging port which you have bought. (I've gone through 3 in a row before!)
No debris in the connection from the port to the board.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Replace tristar ic your problem will go ago.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
cobynew 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 52
전체 시간: 2,431
