주요 콘텐츠로 건너뛰기
Microsoft's third-generation Xbox game console, released November 22, 2013.
727 질문 전체 보기
Power not reaching console
The power brick lights orange but when it is then plugged into the console the light goes off and nothing appears to work. I have tried resetting it by disconnecting everything for a period of time but this appears not to work. Is it a fault of the power brick or is it the console?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Do you still have warranty on it? If so I would try contacting them and see if they can do something for it. In the meantime if you have a friend with an xbox one then try using their Power brick and see if it works that will rule out one or the other.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
No warranty as it is approx 2 yrs old. I am in the process of trying to check out the power brick. I tend to think it's the console because the brick does light up. Thank you for your response
No worries. Hopefully you can figure it out. Easiest way to figure it out would be the another known good device rather its the power cord or the console. I used to love playing on my Xbox 360 then it got a ring on it and I just switched all together to playstation. Best of luck to you!
댓글 달기
귀하의 답변을 추가하세요
David 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 64
