Trouble opening ro replace battery
I am trying to open the bottom to replace the battery but it won't budge. Any suggestions?
좋은 질문 입니까?
좋은 질문 입니까?
You can try heating the end with a hair dryer, this may help loosen the battery cap. It is possible that the battery has leaked and that is making the flashlight hard to open. The heat trick should help with that. If the battery has leaked, try cleaning the interior with vinegar and some cotton swabs.
해당 답변은 도움이 되었습니까?
Maybe use some WD-40 and squirt in near it and let it soak down. Have you tried some pliers of grips to remove it?
해당 답변은 도움이 되었습니까?
Heat the top battery cap while insulating the bottom then put the bottom into crushed ice using a pot holderto hold thw hot cap then use 2 pair of pliers or grips to open
I tried with 2 pairs of vise grips and it won't budge I have no idea what to do.
24 시간 전: 4
7일 전: 36
30일 전: 133
전체 시간: 14,633
댓글 1개
I have this problem too.
Maggie Asberry 의
