주요 콘텐츠로 건너뛰기
모델 A1369, 1.6, 1.7, or 1.8 GHz 프로세서, 64, 128 또는 256GB 플래시 저장공간
328 질문 전체 보기
On startup chime repeats and blank screen
A service person looked at the computer and found it full of lint. His diagnosis is a burned logic board. I was given the computer and ordered from iFixit.com -- a 1.8 GHz logic board, an I/O board, and a new battery--hoping to give myself a virtually new computer at half price. After cleaning the machine and replacing all three parts above I turned it on and the chime repeated itself and a blank screen presented itself the same as the original complaint.
Now what? 1) "New" logic board from iFixit was used and tested, of course. Is it possible to have a repeat problem? 2) Could it be the memory board is the problem? (The only thing not replaced.) 3) I have researched the repeating chime problem from several sites and tried every suggestion all to no avail. It seems there is obviously a hardware problem, but hard for me to accept the "new" logic board that was tested is the problem. Help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
From a second Mac create a bootable OS installer thumb drive following this guide: How to create a bootable macOS Sierra installer drive.
Then see if your system will boot up under it. You'll need to hold the Option key just when you hear the Bong so you can gain access to the drive manager to select the external drive. Once their, run Disk Utility to check your drive. If you have a backup delete the partition and re-install the OS. Let us know how it goes!
Update (03/27/2017)
is there a pattern in the sound? Here's a good Apple T/N writeup on the different startup sounds and the basic causes: About Mac startup tones.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Turned the machine on followed by pressing Option. First thing: no "Bong" --Good. Second thing: The Apple Logo--Excellent! Then... no charge from the external power supply. I found the i/o card power cable was not fully engaged with logic board--thus no BONG. After fully engaging cable I tried again and back to the problem... Bong, Bong, Bong! Alright, I unplugged i/o power cable to logic board and used battery power to start from external boot disk, cleaned the onboard HD, reinstalled Sierra OS and set up the computer. Using a spare i/o card tried again and again the Bong, Bong , Bong and grey screen--no boot up. If the i/o card power cable is not plugged into the logic board the machine is usable on battery power but no sound or camera from i/o, obviously, because it is disconnected.
For some reason there is not a valid boot when the i/o board is plugged in, but there is a valid boot when using only the battery with i/o unplugged.
Did you ever get resolution this problem? I have the same issue: I've replaced the LB and PS. I've disconnected the camera, I've disconnected the speakers. PRAM reset ... no change. How is that even possible, the only thing left is the screen.
댓글 달기
Try clearing the PRAM - not once but THREE times in succession.
If this doesn't cure the fault, then I reckon you have a stuck key on the keyboard.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
David 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 12
30일 전: 24
전체 시간: 3,608
