주요 콘텐츠로 건너뛰기
Apple의 21.5" Intel iMac 수리 안내서 및 지원
2136 질문 전체 보기
Why will my iMac stop recognising the SSD I installed?
Hi all,
I recently replaced my HDD with a Crucial MX300 SSD into my iMac Mid 2011 2.5 GHz, running OS 10.8.5.
I successfully formatted the drive and cloned my data over using Carbon Copy Cloner, checked it was bootable before installing, and installed the SSD, carefully following the OWC video on how to do this. Initially, it booted fine, and I have been working on it for the past couple of days. However, today, something frightening happened!
The iMac wouldn't recognise the SSD at all on start up. It first booted in internet recovery mode, but the disk would not show up in Disk Utility or Startup Disk. I then restarted it, and was met with a circle symbol with a line through it, either on its own, or shortly following the Apple logo. There was also a flashing symbol of a folder with a question mark on it. Since this problem occurred, it has successfully booted up once. But after that, I continue to get these errors each time I boot up. Now, every time I boot up, it just shows the folder/question mark symbol.
I am very concerned about this, mainly because I don't know why it's happening. I did everything correctly, and wasn't having any problems at all, until now. Is there anything I can try to get around this, or potential issues that might be making this happen? Any help would be much appreciated.
Thanks,
James
Update (03/25/2017)
Update:
It turns out that it was the 2.5 to 3.5 enclosure that was faulty. The guys at the shop just taped the SSD in instead in and did without the enclosure. Working fine so far, and I'm currently typing this on it now! Thankfully it was nothing I did. Needless to say the enclosure is going straight back to Crucial, and I'm going to endeavour to get some money for the repair job too.
Thanks for all your help.
James
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Can you give us your exact model as Apple has quite a few different systems in the 21.5" line. Plug in your S/N here: EveryMac - Lookup, then paste the system URL it shows you here for us to see.
댓글 달기
답변 1개
가장 유용한 답변
First CCC is not very good any more. I used it for quite a few years and was quite happy with it! Sadly it doesn't handle things the way you need with the newer versions of OS-X & MacOS.
As an example, it won't prep the new drive with the hidden recovery partition it also messes up some application keys if you also don't use the newest version you can encounter other issues as well. Apples OS installer and Migration Assistant apps are much better as it will create the hidden partition and carry over the keys.
I would start off backing up your data if you don't already haver a backup and then create a bootable installer USB thumb drive so you can scratch the drive down and re-install.
But before you go to all this work how about telling us what your system is and which SSD you put in as that also has a bearing here as well as the version of OS-X/MacOS you are using.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi Dan,
Thanks for your reply. In the end, I've left the computer at an authorised reseller so they can sort it out. I did manage to create a recovery partition even with CCC. The problem was the drive just wasn't being recognised. I get what you're saying about the application keys too, although so far I hadn't experienced any problems with that.
Luckily I have backups of data already, as I can't do anything with the drive as of yet. How would I "create a bootable installer USB thumb drive so you can scratch the drive down and re-install."?
I have already stated the SSD I put in as well as my operating system. However seeing as my Mac has already been taken away, it may be hard to track down the precise specs! I will get back to you on this as well as the outcome once it comes back from the reseller. Let me know if there's anything else that would be helpful or that I can find out at this point.
Thanks,
James
댓글 달기
귀하의 답변을 추가하세요
James Price 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 117
