leaking water out bottom of coffee maker
my keurig k40 is leaking water from the bottom
좋은 질문 입니까?
좋은 질문 입니까?
There are several possible causes.
The easiest to check and fix is that the holding tank is cracked and leaking.
Its also possible that the needle is clogged up with grounds, you can use a paperclip to clean out the needle.
It could also be that something is broken inside the which is difficult to diagnose without taking it entirely apart.
해당 답변은 도움이 되었습니까?
The bottom needle broke off with the plastic it it modes to.
Is there a replacement part available?
해당 답변은 도움이 되었습니까?
There are some easiest ways to fix this problem:
Faulty O-Ring
Inspect The Water Reservoir
Keurig Needs To Be Descaled
Broken internal Part
you can see all the solutions on this guide How to Fix Keurig Leaking Water/Coffee From Bottom
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 4,796
