주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Drop on back bootloop, repair shop fail
I'm currently travelling, and whilst in Cuba I proceed to drop my phone flat on its back which causes it to bootloop. This happened to me in Canada as well, where I opened it up reseated the display cables and was good to go, when I tried this in Cuba, it did not solve the problem. It was and is still in a bootloop on the apple logo and then black.
From research on this site I assumed it was an issue with the battery, so I have taken it to a repair shop where they reseated it and tried a new one, but it failed to fix the issue. It is still in a bootloop.
They gave a load of excuses and no real reason to why it is broken other than my jailbreak my have been the cause, which I find very hard to believe. They then suggest that I try a restore, which I have just attempted to which I get error (9). Which I think means a hardware issue.
If the battery is not the issue, the only hardware problem I can think of is from screwing the wrong screws on the guard of the display cables, would this be the cause? How do I go about checking this and fixing it?
iPhone 5s 10.2
Jailbroken Yalu b7
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
Did you try a DFU mode restore?
I haven't, sadly my laptop has died so cannot restore at this point, I will give this a go once i get my laptop repaired
Finally have my laptop up and running and sadly this does not work, DFU restore simply returns the same error 9
댓글 달기
답변 2개
가장 유용한 답변
on my quick 2 minute research it seems error 9 is an error in updating i have found this link though witch could help a lot.
How to fix iTunes error 9
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
For me it sounds like a corrupted NAND
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
what does that entail? sorry no phone and now no laptop, whilst half way across the world, so can't effectively google
This is the device's memory chip.
Sweet, apologies for my ignorance, I'll email some repair shops see if they can fix this issue
댓글 달기
귀하의 답변을 추가하세요
charlie.smith142 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 75
