My lenovo a6000 cant power on
I have a problem with my lenovo a 6000, the phone cannot turn the power on but still ok with charging. I have check the battery and the condition is ok . Anyone can HELP me to solve my problem?
좋은 질문 입니까?
좋은 질문 입니까?
On a lot of the lenovo tablets and phones there is a reset button in the SD card slot you will need to reset it. Not sure on your model but its worth a look . If theres not one then try removing the battery then leave it sit for an hour and then put the battery back in and reboot the phone . While you have the battery out it wouldnt hurt to check the battery with a multi meter against the power out specs listed on the battery. Hope this helps
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 8
30일 전: 26
전체 시간: 7,464
댓글 3개
Does the phone instantly shut off when you unplug the charger? If so then the battery is probably unable to hold a charge and needs to be replaced,
Jacob Micallef 의
My Lenovo A6000 shutdown on recovery mode .. now dosnot turned on ..wht can i do ??? Plz help
Akshay panigrahi 의
Golu Kasar 의
