주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Speaker option is Grey out while making a call
Strange Situation. On one of my Customer, I phone 6. Speaker option is grey out while making a call. I have reset the I phone but still the same. Check the Loud Speaker is working but the option is grey out.
any inputs on this ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
If you don't mind me asking. What solved this issue?
Because personally I've never solved this issue for a customer and just end up saying an issue with the logic board (can't spend too much time when I offer on the spot iPhone repairs on weekends at a market).
댓글 달기
답변 1개
선택된 답변
Can you test if the proximity sensor is working? (Place phone near your ear and screen should turn off).
Have you tried using earphones and see if the sound works through there during calls? Especially one with in-line microphone on it.
Also check the screw holes on the logic board specifically at the screen FPC ribbon connectors on the logic board for any long screw damage.
Usually you'll see threaded marks in the screw hole or copper being exposed under a microscope.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Hi I have this same issue and the proximity sensor does not work, also the headphones produce no sound when making calls, any help?
i think the dock connector is the problem
댓글 달기
귀하의 답변을 추가하세요
Shahil Samnani 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 25,857
