What could cause new keyboard malfunctioning
Changed keyboard because of beer spill (a few month ago) and the right side of the new keyboard is not working. When I connect an external keyboard as I've been doing to get along, everything is fine. Thks for any help.
좋은 질문 입니까?
댓글 4개
Really a new keyboard or a used one ?
lemerise 의
Absolutely. direct from Apple
Pierre Terrien 의
Since it's a liquid spilled MBP check for corrosion inside the keyboard socket (where yo connect the kb) and if you find any clean it with a toothbrush and isopropyl alcohol. If that does not work then the logic board could be affected or the new keyboard could be faulty. Bonne chance Pierre...
lemerise 의
Tks to both of you.
No apparent corrosion, so I re-seated kb connections at both ends and everything is OK.
Merci and best wishes!
Pierre Terrien 의
