주요 콘텐츠로 건너뛰기
Repair guides and support for your LG TV.
1342 질문 전체 보기
Can someone fix the HDMI 2 port, which has pushed in?
The HDMI 2 port has somehow become mangled; it ;looks like it has been pushed in, and I don't know how to pry it out or whether prying it will damage it. Are there people I can hire to do this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
yes what exact model is your TV?
If you want to try to fix this, you probably need to take the tv apart. And if it is bent, its pretty much screwed anyway as some pins probably broke which are a pain to fix
Bless you! I will look for a computer repair or TV repair person. Thank you so much.
댓글 달기
답변 1개
선택된 답변
yes, Yes the HDMI 2 port can be repaired, yours could be soldered directly to a board which takes some skill to reattach if undamaged or replace if need be. Any good local TV repairman or computer repair shop can probably perform this task. The link below will give you an idea of what is involved in the repair of a loose HDMI port. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=lxJJ-9xP...
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
yes, did this help answer your question.
댓글 달기
귀하의 답변을 추가하세요
yes 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 33
전체 시간: 6,643
