주요 콘텐츠로 건너뛰기
Released March 2016, the Rift CV1 is the first consumer-targeted virtual reality headset by Oculus.
33 질문 전체 보기
How to fix HMD disconnection?
My Oculus Rift headset is constantly disconnected, and the "We can't find your headset..." notice will pop out, I have tried everything on the software end including setting usb power management and got the officially recommended Inateck PCI-E USB card, which didn't help either. The headset will disconnect randomly and also when I give pressure on the top of the device, especially on the top left nearby the HDMI plug. Wondering if this is caused by the hardware defect and it would be highly appreciated if you could tell me how to fix it. Thank you very much!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
It sounds like a defect. Like a loose wire. My friend had one that had the same problem and he just sent it in under warranty, is your's under warranty?
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Bocheng Lin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 12
전체 시간: 1,578
