How do I change IR 2520 default scan mode from TIF to PDF?
Hi.
How do I change the default scan mode from TIF to PDF?
Canon ImageRunner 2520.
I dont find it in administraive menu.
May be this change by service mode?
좋은 질문 입니까?
Hi.
좋은 질문 입니까?
1. Press the Additional Functions button.
2. Select Communication Settings.
3. Select TX Settings
4. Push the down arrow on the screen until you can select Edit Standard Settings.
5. Select PDF (or other formats) as your default.
additional funcitons>common settings>TX functions>Edit standard send settings. Adjust your settings hit OK and store
해당 답변은 도움이 되었습니까?
Thanks bob that you find solution and upated the thread here.
Launch SwifDoo PDF and upload a TIF file to the workstation;
No limit in file size, no registration
해당 답변은 도움이 되었습니까?
Great Bob you help it. But if you are looking for a pdf software for files. I may recommend you PDF-XChange Editor Crack , which is i am also using for open the PDF files.
해당 답변은 도움이 되었습니까?
24 시간 전: 3
7일 전: 3
30일 전: 15
전체 시간: 5,901
댓글 1개
https://support.usa.canon.com/kb/index?p...
Bob 의
