주요 콘텐츠로 건너뛰기
Here you will find several different repair guides for the Dell Chromebook 11 (CB1C13) - 2GB & 4GB models
11 질문 전체 보기
Is it feasible to replace the headphone jack?
Do you think it would be feasible to replace the headphone jack in this device? Is it soldered down or otherwise permanently fixed in place, or would it be possible to remove it without risking damaging other parts?
Thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Peter Town, Yes it does appear the headphone jack is soldered to the board and further damage could result from inexperienced person trying to resolder or replace because of heat required to resolder/replace. Below are a couple links, partial disassembly guide to get you inside to check out the jack. 3rd link shows how a jack is replaced so you can see what may be involved, in case you would like to try it. If not wanting to attempt the repair your self pop into a local good computer repair shop for an estimate. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Dell Chromebook 11 CB1C13 Battery Replacement
http://dev.chromium.org/chromium-os/deve...
https://www.youtube.com/watch?v=EICrlw3G...
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Peter Town 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 2,336
