Why do I have horizontal lines down the screen
I have horizontal lines down the screen,the phone is working fine but the lines are annoying. How and what do I need to do to fix it?
좋은 질문 입니까?
좋은 질문 입니까?
@nitramet ,Trent, Could be a couple things possibly LCD connection has come loose or LCD has been damaged. I will post a disassembly link below so you can get inside the device and check the connections/clean with Qtip dampened with 90%+ Isopropyl Alcohol and reseat connection and try. If display still bad then it is probably a bad LCD. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
해당 답변은 도움이 되었습니까?
Can u plz tell me how I can fix the lines in My phone
How do i get the lines from going down my phone
Should I turn the phone off and then turn it back on again
해당 답변은 도움이 되었습니까?
I just faced same problem. Any solution you find out yet?
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 5,164
댓글 1개
Mine too. But my mobile fell and later after a couple of days, it over heated after a prolonged video meeting, then horizontal lines appears and are irritating
Patrick Kutumela 의
