syma x8c two props dont spin
so i went to fly my syma x8c after my friend crashed it pretty hard, and only two of the props spun( the front right and back left) so i checked the motors and i checked gears and everything was good i even switched out the motors to the stock ones and same result. i took off all the props to see if anything would spin all four spots were working fine. i put the two front on and tried it, it worked fine. i put a third on and that front right stopped working its like their isnt enough power for all four of the motors. i swapped out batteries and nothing changed. i tested it once and throttled it very slowly all four spun until i got to a certain speed then the same two stopped working. even when all four were spinning the drone would not move it seemed like its filled with rocks. nothing extra is on the drone.
UPDATE
i tilted it around and all four spun. i held it in my hand and all four spun but as soon as i set it on the ground only two spun. it also seems to be pushing down instead of up. yes the propellers are on the correct way
좋은 질문 입니까?
댓글 3개
i also tried calibrating it and nothing changed
mike schmitz 의
While the props are spinning, try tilting the drone, alot. Something may be wrong with gyroscope.
George A. 의
i tilted it and you were correct all four motors spun. is there anything i can do about that
mike schmitz 의
