주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2006년에 출시된 제품, 모델 번호 MID9742
Lost kyross entry passcode
Lost kudos passcode. Will reformat tablet override??
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Yes it will remove pass
의 공유
l. Pfaf9sI'm grateful you write but I still came get home button to bring up scroll menu screen.
의 공유
댓글 달기
답변 1개
가장 유용한 답변
Nicole Turner, If you have forgotten pass code, reset procedure below will get your back into(unlock) tablet. .Info. found at androidtablets.net. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Master Reset Procedure.
Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Click "Power Off" and select "OK"
Once the unit has been turned off. Press and hold the "back" button(silver tone button) and "power" button simultaneously for eight seconds.
When the Android Icon and warning triangle appear , press the "back" button )silver tone button) once.
The Android recovery screen will appear. The "Home/Menu" button will allow you to scroll up and down.
Press the Home/Menu button to scroll to "Wipe Data/Factory Reset" Then press the "back" button
On the next screen Scroll to "yes-delete all user data" Press the "back" button.
On the next screen Choose "reboot system now" and Press the "back" button.
You will now be able to access the tablet.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Will this work with kyros. Mic 9740
의 공유
I'm sorry that's auto correct got me . It's suppose to be MID 9740 THA KS
의 공유
댓글 달기
답변을 추가하세요
Nicole Turner 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 15
전체 시간: 770
