주요 콘텐츠로 건너뛰기
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 질문 전체 보기
Original 3ds, blue light turning on and then turning off
Hi there i have a 3ds CTR-003 model and yesterday i tried to turn it on but the blue led indicator flashes for 1 or 2 seconds and the console does not turn on it does not make a popping sound ether i have no clue what it might be .
Update (05/12/2017)
i installed A9LH susceffuly and know its turning on but it keeps spasing out always going down i dont know what it might be any ideas
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
Did you by chance try to install A9LH or Luma before this happened?
댓글 달기
답변 1개
가장 유용한 답변
This is a brick, unless you have a NAND backup then you may not be able to easily recover it.
If you have a NAND backup then follow this guide and set up your SD Card with the NAND Backup and the GodMode9 app, boot into GodMode9 then install the NAND.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
댓글 달기
귀하의 답변을 추가하세요
hugoifer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 7
전체 시간: 3,231
