There is oil mixed with The water in radiator of. my Chevy S10
Mechanic told me could be I need to replace seal on my intake? Does he mean intake manifold?
좋은 질문 입니까?
좋은 질문 입니까?
What years the truck and what motor is in it . A mix of oil in the coolant can be a result of broken seals in the intake manifold or the head gaskets . Something you may want to look into before fixing the truck is , is there coolant in the oil as well, does the oil on the dipstick look like chocolate milk or coffee with cream . is there a creamy scum on the bottom of the oil filler lid? If the answer is yes to any of these then its more apt to be a bad head gasket . If the oil is milky then the bearings in the bottom end will need to be replaced as well as the rod bearings and wristpins . If you just replace the gasket and don't address the other issues then its only a matter of time before the motor goes completely. Hope this helps
해당 답변은 도움이 되었습니까?
christinezaf , Yes,(faulty) intake manifold gasket is one possibility to get oil contamination into the coolant. He may have performed a pressure test to determine this. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 2,228
댓글 1개
Should I replace seal on intake manifold?
christinezaf 의
