주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
일본 이외의 모든 시장에서 판매된 3세대 Toyota Camry. 1991년~1996년형 모델은 XV10 시리즈 Camry 차량이라고도 불립니다.
Cam sensor location no spark issue
I have been trying to get this car going for about a year.told that the cam sensor is gone and need to replace it.now I'm no expert but I do know that I have watched a few videos on YouTube and where they show the cam sensor to be at it isn't..Then told that it's apart of the distributer shaft.!!!!! So if that's the cam where's the Crank shaft sensor? I ts a no spark issue
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
@lowvisions , Patrick , On the 2.2l engine, crank position sensor is behind the crank shaft pulley/balancer. Picture below(crank sensor circled). For the V6 3.0l almost same position, see video link. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=M6zU6jh8...
이미지
이 답변이 도움이 되었나요?
점수 3
댓글 4개:
I'm sorry I should of mentioned that I have a 3.0
Patrick, For the V6 3.0l almost same position, see video link. Thanks for replying back.
On the 2.2 do u have to take the timing cover off to get to the sensor
We have a 1996 Camry LE 2.2L 4 Cylinder... I have bought the crankshaft position sensor, I just dont know where the heck to install it, where is the old one? Anyone know? I searched it up on youtube but i could not find anything. I hope someone can help
댓글 달기
Hi for all Ihave toyota corolla 1993there’s no cranck shaft sensor but there's acumshaft sensor biultin within the main distributor shaft making signale to the ECU of the car
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Well I have remove my 2.0 l and installed a 2.2 l engine , and the car didn't use a distributor , it uses coil which depend on a crankshaft sensor
@elicaannephembani And the point of bumping a thread that's almost 2yrs old is...? Are you having issues? Or what?
댓글 달기
답변을 추가하세요
Patrick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 87
전체 시간: 10,687
