주요 콘텐츠로 건너뛰기
The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
Broke LT and RT holders how do I replace it?
I have provided two pictures, the blue controller is the one that I'm trying to fix. The dissasembled controller is the one I'm using for the RT and LT.
I want to remove the Trigger holder from the controller but don't know how to do it.
It's the metal piece holding the Triggers.
I need help guys.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
Hello, my RT button on my Xbox One controller is not working correctly. When I get on NFS the car drives by its self.
댓글 달기
답변 6개
가장 유용한 답변
https://www.youtube.com/watch?v=NZp8Rcik...
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks for that
댓글 달기
Hello @imzai,
There is no photos as I can see, did they upload correctly?
Well, I provided a few IFixIt links that may help
Xbox One Wireless Controller Trigger Rumble Motor Replacement
Xbox One Wireless Controller Buttons Replacement
I hope these help!
Thanks,
Keegan
Xbox One Wireless Controller Model 1537 Trigger Rumble Motors 이미지
안내서
난이도:
어려움
15 - 20 minutes
Xbox One Wireless Controller Model 1537 Buttons 이미지
안내서
난이도:
어려움
30 minutes - 1 hour
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
I have edited my post, I've uploaded the pictures, what I mean to to remove from dissasembled controller is the metal stick holding the triggers.
Okay I see, so if you look back in to the link Xbox One Wireless Controller Trigger Rumble Motor Replacement it shows how to remove the moters. So, I think by the look of the photos its soldered to the board. Can you confirm this?
댓글 달기
You have to press the small part of the metall pin then it comes out on the other side where you can grab it with pliers / tongs / nippers and pull it out gently.
You have to be very carefull, else you destroy the trigger or the frame.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I need a LT trigger spring
이 답변이 도움이 되었나요?
점수 0
댓글 달기
How to take this off lt button
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Same here, my rigger holder is broken too
댓글 달기
My left triggers has came out of the socket please help
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
J Angel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 68
전체 시간: 30,436
