주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
How to fix screen issues after screen replacement?
Hello, earlier today I put a new screen on my iPhone 5c to replace a cracked one that caused a similar problem that i am experiencing now. After i finished, i noticed that the colors were kind of dimmed and the left side is black (see picture). Any advice on how to fix this? I also noticed that the screen was a little lifted from the surrounding casing on the phone. Could it be a bad battery? The screen is still responsive. Picture
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Hi, the picture that you provided would indicate damage to the LCD. The solution to this problem is it carefully install a new screen assembly. This will solve the black part and any funny colors. As far as the battery, does it appear to have any wear marks on the battery from swelling and touching the LCD metal bracket? This would indicate that you need a new battery. If you have a voltage tester, you can remover the battery connection and test the battery for proper voltage.
해당 답변은 도움이 되었습니까?
점수 2
댓글 5개:
TL:DR - Replacement screen was either improperly installed or the internal LCD came damaged like that.
OP could you post a screenshot of the inside of the phone particularly at the battery? Sometimes this causes the screen to be pushed up like Nick said.
So should I buy a new LCD Digitzer ? And I will post a picture of the internals when I get home.
Yeah, the one installed right now is physically damaged and needs replacing to fix.
I am thinking about just having it professionally repaired
댓글 달기
It is probably faulty screen. Aftermarket screens for 5c are notoriously bad. I tried a 2 from ebay and 1 from Amazon with the same result. Finally bought one from iFixit and to date (5 months later) no issues.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jackson Sindaco 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 58
