주요 콘텐츠로 건너뛰기
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 질문 전체 보기
How to remove the circle gray spots in the screen of iPod?
Has gray circle spots in the screen and the edge of the circles has a yellowish color.
- how to removed that without opening the iPod touch? And also without deleted the files inside of the iPod touch?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 4개
선택된 답변
It is a defective LCD, it had developed grey spots and unfortunately you will have to open it up to fix it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
OK. I have one of those gray spots. In fact, I had two, a large one (about the size of a penny) and a tiny one. They appeared after my 5 year old daughter sneaked a while with the ipod. I had accepted she should have hit the screen an so it was a dead spot. I could keep using te ipod, so I did nothing. Yet, after a few months, the small spot disappeared. So, the screen spot wasn't really a dead spot. It came back to live. Now, a month later, the large spot started to move on its own. It has moved almost a quarter of an inch. That is, a good part of the screen that I had assumed dead is now working perfectly well (I can now see the battery status, which I couldn't with the original spot location). Unfortunately, it is moving towards the center of the screen, rather than outwards, as I would like it to. I wonder if someone had seen this before, and whether there is a way to make it move the way I would like it to? It actually seems to be moving downwards, since te ipod is mostly standing on a charging cradle.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Hope this video helps. It helped me remove spots from my Sony tablet. https://www.youtube.com/watch?v=PxUOlqaN...
댓글 달기
Those are dead spots in the digitizer. You are going to need to replace the screen assembly. You won't lose any files by doing this.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
The digitizer is the touchscreen, that does not make any sense.
l,;lhljmklghljg;lhlgl.h.lgljlgv.jll,b,cf,lbhnfb ngbngvnfjngnmfnmbgn
댓글 달기
I've moved the grey spot around, there where tons of small ones on the screen after a sharp drop of my phone, then I started to move them around until a big grey dot has formed at bottom -left of screen, the size of home screen button, although I'm not able to push it out of the edge., ( the spots become more fluid like when heated, and solid and bit compressed when cooled, used a heat gun and fridge) any suggestions on pushing it out? I'm using iPhone 4,
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
khatee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 25
전체 시간: 15,163
