주요 콘텐츠로 건너뛰기
How do we remove The Shard glass on the bezel area from the frame or lcd
Everyone asked about removing the glue I'm trying to remove The Shard glass from the LCD frame area before I even get to the glue issue does it require Heat or some kind of adhesive remover thank you
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Ty so much I appreciate that
댓글 달기
답변 1개
선택된 답변
Heat is result your friend when it comes to these acceeen replacements. The glass is help together to the bezel by strong adhesive. Be sure and not get it too hot. 170* is usually the perfect temperature. Heat up a small section, move the glass and work your way around the glass until it is all off. Be sure and not heat it too hot as it will warp the bezel. The glue is rather tough on the iPad 1 compared to the other models.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
mikeyperron1 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 66
