주요 콘텐츠로 건너뛰기
Released in 2013; Android operating system; 8 inch screen size
5 질문 전체 보기
wont charge but it should
This tablet is not charging.
-when i plug in charger it can comunicate with PC
-when i test it with multimeter it shows 4.35V connected to PC , 4.55V connected to WALL. ( on battery it says input : 4.35V)
-i tried to change battery and same thing
-when battery is charged , phone works but battery % are droping and than it turn off...when i try it with charger plugged inm than it is dropping even faster
-i tried to leave it charging for hours and nothing changed...
-sometims i can turn on tablet and it shows battery is charged to some %, but it starts to drop really fast again
-i tried hard reset
-charging port looks in perfect condition, and when multimeter shows it is ok i dont think if i replace it, anything will change
-of course i tried multiple cables
-when it is plugged in and i want to turn it on, it just show battery lvl for second and turn off... i need to plug it off to turn it on
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Is the charging port soldered to the motherboard? are the solder points visable/available to test with a multimeter?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
yes it is and as i said before it looks in perfect condition from inside and outside. it comunicate with PC also
댓글 달기
귀하의 답변을 추가하세요
PS15 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 112
