주요 콘텐츠로 건너뛰기
A point and shoot camera manufactured in 2015 by Nikon.
28 질문 전체 보기
My lens is stuck all the way out!
My lens is stuck all the way out it keeps telling me to put the cover back on and shut the camera off i do and it won't engage it to go back in HELP HELP HELP I've only used this camera like 15 times it's new GRRRRRRR...
Appreciate any help Thanks !!!!
Donna
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
My Nikon Coolpix L340 lens rattles inside when I zoom in, what is happening? I believe it could not be attached properly.
댓글 달기
답변 4개
선택된 답변
@lv2kiss ,Donna, Look around the gap between lens and camera body and if you see any debri/sand/etc. tear a small piece of paper to use to circle around the lens to dislodge the debri or hold upside down and give a good shake(do not drop).
Remove battery and memory card, hold down power on button for 10 seconds, re insert battery and power on then off.
If no dirt and reset did not work, battery is known good and fully charged and lens will not retract, return under warranty for repair/replacement/refund. Your camera internal lens mechanism could be faulty. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
해당 답변은 도움이 되었습니까?
점수 6
댓글 1개:
I have problem on zoom
Zoom not completely to end stop between W and T
댓글 달기
YES i had 1 battery not charged THANKS !!!!! bLH gastonia@aol.com
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I am going on a trip soon and now my camera broke. What a coincidence! I am so frustrated!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had this problem. Constant switching off (by opening the battery case - the only way!) and on again coupled with illogical manhandling of the lens with occasional thumps eventually got the thing running with poor focus. Then I went to menu-settings-reset (to factory default)-ok and it now seems fine. Minutes away from binning, or home dismantle which would have had the same outcome!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Donna 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 33
30일 전: 106
전체 시간: 8,889
