주요 콘텐츠로 건너뛰기
A portable wireless bluetooth speaker introduced in 2013 by Beats by Dr. Dre.
27 질문 전체 보기
Battery life indicator not showing charge
When I put the power cord in it doesn't let me know that it is charging and when I press the power button it doesn't let me know how much power the battery has but it came on once a few days ago both were working but now it is not and it has been like that for some time now can you help me
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Larry Shorter, I believe the Beats Pill XL were recalled. Apple has determined that, in rare cases, the battery in the Beats Pill XL Speaker may overheat and pose a fire safety risk. 1st link below will take you to recall info..
The battery, cable/charger or charge port may be faulty damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connections and reconnect/install battery, still not charging battery probably faulty. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the tablet to check the charge port and battery. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.apple.com/support/beats-pill...
Beats Pill XL Motherboard Replacement
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Larry Shorter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 2,050
