주요 콘텐츠로 건너뛰기
The 1998 version is based on the original Beetle but, in comparison with the old model of the vehicle, it is way more spacious and equipped with more advanced features.
33 질문 전체 보기
Why am I seeing a new warning light every time an issue is fixed
Had relay switch replaced on 05 beetle then...
warning light for brake issue appeared
had that fixed,supposedly having a lot of "brake dust all down side of car"
Was told when it was scanned, had 11 issues
Mechanic stated cleared all and it should reset itself, now blue temp/coolant warning light is on
I'm starting to think I'm sinking money into a car that isn't worth it.
would clearing it and hope it fixed itself sound logical?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@pamsbeetle05, Pam, would clearing it and hope it fixed itself sound logical? NO!Sorry you are having problems with your 05 Beetle. Just clearing codes will not repair the underlying faults. I am sure the technician did this in hopes some of the issues may have been just a glitch or just to give a clean slate to see what would have to be dealt with. Now that codes/engine light reappears is confirming there is a problem and it needs corrected. If you feel you do not trust the shop presently working on the car try another good local shop and have them take a look. Some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue's like your's often and put you on the right track. Until you get estimate on the repairs required, can not say whether it is worth it.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Pam Justh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 47
