주요 콘텐츠로 건너뛰기
모델 A1347과 2.4 또는 2.66 GHz Core 2 Duo 프로세서.
76 질문 전체 보기
Is there a 'unibody' Mac mini teardown manual?
We're looking into getting a new unibody Mac mini soon. We wanted to know if the new thicker hard drives would fit. Does anyone know if there is a unibody teardown manual that might have this information?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
From a visual standpoint it looks like these use 9.5mm drives from the factory. These may take 12.7mm drives, but I'd check with a deck of cards to be sure unless you have a spare 12.5mm drive you can quicky use. If you'd rather be safe stick to 7-9.5mm drives. However, you need a drive with a SATA II compatibility mode and cannot use a Fixed III drive.
Follow this guide to change the hard drive.
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
Thank You nicksmacandpchelp!
The current Mac mini is MC270*. Is there much difference between it and the A1347?
+ The MC270 is the A1347.
OK, THANKS for clearing that up.
댓글 달기
귀하의 답변을 추가하세요
AngelArs 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 1,438
