주요 콘텐츠로 건너뛰기
BLU Vivo 6 cracked screen
Hi all,
I managed to drop my BLU Vivo 6 phone to concrete and the screen is now cracked. It works fine, only the glass is broken.
I found webpage where you can order new glass, do you have any ideas is that enough or should I order digitiliaser (or display) as well?
BR,
M
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
To answer this question, how much trouble are you willing to go through to save a few bucks.
Separating the glass from the LCD is delicate, and you could irreparably damage the LCD and Digitizer.
Once you successfully separate the glass from the rest, you need a UV light and LOCA glue to put everything back together. This also is a risk because if you don't know what you are doing, you can have permanent bubbles under the screen, the digitizer may not work, and you may have glue going into parts of the phone you don't want it to go.
I would order the entire LCD assembly which reduces the risk and trouble of reassembly.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Mikko 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 575
