주요 콘텐츠로 건너뛰기
Samsung의 5-세대 Android-기반 Galaxy 스마트폰은 2014년 4월 11일에 출시되었습니다. 이 휴대폰은 지문 스캐너, 최신 카메라, 대형 화면 및 방수 기능이 개선되었습니다. 네 가지 색상으로 제공됩니다; 검정, 파랑, 흰색 및 구리.
577 질문 전체 보기
Why does it stop working when I get incoming calls?
When I get an incoming call, sometimes it just reads that the phone stopped working and when I press OK it pops up again and I can't answer the call and have to reset the phone completely. Is it a common problem and if so, does anybody know if and how it can be fixed?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
I would recommend connecting to Wi-Fi and make sure that your phone is updated to the latest version of Android OS available. Also check to make sure that your carrier settings are up to date as well. This can sometimes be caused by the Android software trying to use the Phone app and not having something that it needs to continue, so the app fails and shuts down. Hope this helps!
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I tried updating the software but it still happens. Any other suggestions?
The only other thing I can suggest is to make sure all your apps are updated, if that doesn't work, try to *first* back up all your data you want to save... then to a factory data reset.
댓글 달기
귀하의 답변을 추가하세요
Bor Turnšek 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 48
