주요 콘텐츠로 건너뛰기
Released in November 2012, the GoPro HERO3 is a Wi-Fi capable, 4K resolution digital camcorder.
104 질문 전체 보기
Broken charger port on go pro 3
Can the charging port on a GoPro 3 be repaired or replaced
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
@rappin9 ,Rodney, The charging port on a GoPro 3 can be repaired or replaced. This is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the GoPro Hero3 to check the charge port and will also post a link showing what is involved in repairing/replacing a mini USB attached to the board. The last link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
GoPro Hero3 Teardown
https://www.youtube.com/watch?v=tLgm3L1U...
http://www.ebay.com/itm/Gopro-Hero-4-and...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I got fixed by a company in Montreal, it cost me CAD$80 and they did a great job just in 24 hours working as new again.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Sebastian - which company in Montreal fixed it? i have the same problem. Merci!
댓글 달기
귀하의 답변을 추가하세요
Rodney Esposito 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 15
전체 시간: 3,520
