주요 콘텐츠로 건너뛰기
"The worlds smallest 15.6-inch laptop packs powerhouse performance and a stunning InfinityEdge display all in Dell's most powerful XPS laptop."
Can I add an HDD 2.5 or SSD?
Hello,
I am looking to buy an XPS 15 (9560), but I would need more memory than 512Gb.
Could I add an internal HDD?
Regards
Ricardo
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
you are asking two questions. or you may be confused on parts. first memory is not the same as a hard drive. so are there two questions or just one?
댓글 달기
답변 3개
가장 유용한 답변
Ricardo, it looks as if you can add a 2.5" HDD or SSD. The factory SSDs are in a M.2 or mSATA slot, leaving the HDD bay open for upgrade. You may want to consider a Seagate firecudas SSHD for not much more than the price of a regular HDD.
Hope this helps!
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
This is only possible on the version with the smaller battery. The version with the 97Wh battery has no room for a 2.5" drive.
Source: I own both version
댓글 달기
yes you can up to 1TB
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I would like to know where you got this information.
댓글 달기
Yes you can if you have an FHD model. Consider that you'll need an adapter. You can easily find it online
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ricardo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 15
전체 시간: 8,773
