주요 콘텐츠로 건너뛰기
Unibody가 아닌 Core Duo & Core 2 Duo 프로세서
375 질문 전체 보기
broken connector for the camera and FaceTime
The silver connection for the camera cable has broken off at the board. Is this fixable on a MacBook pro A-1398? If so where can I buy the connector. Its a flimsy connector that takes very little to displace from the board.
Ever since this happened my fans continue to run at high speed. I have attempted on several occasions the recommended resets by apple but this hasn't solved any of the issues.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 2개:
Did you figure anything out? Happened to mine as well. Thanks
Melted the connector. No sucess
댓글 달기
답변 1개
I am assuming that you have a 15" Retina MacBook Pro model between late 2013 and mid 2015 - you wrote A1398 in the question but chose a different model to file the question under.
You can replace the connector, however, this will require soldering equipment and some experience with microsoldering. You can buy the replacement connector here: https://beetstech.com/product/isight-cam...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kevin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 433
